ArcGIS Pro - Modify Features - Python
2023
01-10-2023 06:56 AM
DirkThuynsma
Good day,
I am using ArcGIS Pro with a standard license. I used the "Modify Features -  Split" tool and can't seem to find a script for the tool. I did not use the "Analysis - Split" tool since I do not have a advanced license.
Is there any python scripts available?
Cheers,
DougGreen
Oh that's a good question. The "Split a Feature" functionality is an active-editing, interactive tool where you specify the location at which you want to split the feature. This means it isn't available as a python Geoprocessing operation but I could see a way to perform geometric functions (read and write) to perform the task. However, there's also a geoprocessing tool called "Split" that chops up a set of features using another set of features. This can be run in python using parameters. I imagine you're talking about the first one though?
DirkThuynsma
Hi Doug,
The geoprocessing tool called "Split" would be the perfect tool to use but the ArcGIS Pro standard license does not include this tool. Do you have any other suggestions?
DougGreen
Oh I am sorry I didn't realize that. It doesn't seem like something that common would require an advanced license. You could search the Code Share to see if anyone has shared an existing script.
