ArcGIS Pro Map Topology
1065
10-30-2023 01:12 PM
ClintBoaz1
In ArcMap, when using map topology you are able to choose which features in your map will participate through the select topology window (image below).  You are limited to features in the database your edit feature is in but you are able to choose features individually.  In ArcGIS pro, when using map topology all features both editable and turned on in your map participate in map topology.  There doesn't seem to be a way to choose features individually.  Has this functionality been lost in ArcGIS Pro, or is there a different way to have an editable layer turned on but not participate in map topology?
LaraOles1
I too would love an answer to this question...
