I'm currently importing the shape files from MSSQL and the layer is drawing incorrectly with straight lines on top (see the below img).
These random lines do not appear when I import the shape files from the local drive, only occurs if the data is coming from the database
I have tried:
• Repair the original shape file using arcgis pro's repair geometry then re-imported to MSSQL
• Repair using SQLLITE's .MakeValid() and checked for validation using STIsValid(). All data returned valid.
I used:
• Ogr2ogr for importing shape files to MSSQL server 2019
• ArcGIS pro 2.5.0
**Side note: These lines do not appear if I'm on QGIS, which makes me think this is not a data issue...
Your help would be much appreciated!
Have you tried rebuilding the index?
It looks like one of the polygons may self intersect.
Thanks for the reply George.
I tried rebuilding the index in ArcMap and that didn't work for me...
However, the layer was drawing correctly on ArcMap without the random lines.
