I am using ArcGIS Pro 2.7 and recently noticed there is an issue with longitude values for -180 or 180 not being recognized by the software. These longitudes are recognized in ArcMap. I didn't notice this at first, but created a feature layer from the points in AGOL and these points are used in an Experience Builder app. The issue is carried forward all the way to Experience Builder. Although in AGOL the points with the -180 longitudes do show in the Classic Viewer, but not in the New Map Viewer so there seems to be all sorts of issues.
This area at -180 to work with in Esri software really is an issue, but to not recognize the longitude at all is a step way back. This morning I was trying to diagnose and used the Go To XY in ArcGIS Pro to add in the coordinates of 54.5, -180 and a person can't even enter in -180 or 180 (see screenshot below). In ArcMap, using the same tool the program recognizes both -180/180 as legitimate coordinates.
So one issue is the desktop software, but the problem extends to AGOL in my experience with similar issues between Classic Viewer and New Map Viewer, with classic showing the points and the new map viewer not working. Finally I have an Experience Builder App and the points do not show here. I first noticed the issue here when filtering the points and noticed some were missing.
This has to be a bug right? The documentation for ArcGIS Pro states this:
"Latitude and longitude values represent an x,y coordinate location on the map. You can map x,y coordinate data using the World Geodetic System 1984 (WGS84) coordinate system. In this system, latitude (y) values range from -90 to 90, and longitude (x) values range from -180 to 180."
Are others having this issue?
Kathy
