ArcGIS Pro Indexing Server
1841
02-28-2022 01:17 PM
LaurieKurilla1
Why is ArcGIS pro Indexing server running when I am not using ArcGIS Pro?  As you can see below it is showing HIGH (as seen below) to VERY HIGH power usage and significant CPU.  I have not even initiated ArcGIS Pro since booting up.
DuncanHornby
MVP Notable Contributor
You can turn off the indexing behaviour from options:
LaurieKurilla1
Duncan,
Thank you for your prompt and informative response.  What will be the impact on the running of ArcGIS Pro if I make changes to the indexing server?
Laurie
DuncanHornby
Have a go, you can always turn it back on!
