ArcGIS Pro Icon
2151
10-05-2022 08:13 AM
LaraOles1
Does anyone know why my project icon, the toolbox and the Layerfile all have a gray X on them?
Thanks!
DanPatterson
MVP Esteemed Contributor
was anything moved to a new location?
... sort of retired...
DanPatterson
LaraOles1
Hmmm, it was about a year ago I worked on this but yes, I think I moved it to a new folder called Data.  Now that I have more experience under my belt, it seems that projects, toolboxes and the gdb are usually in a folder with the same name as the aprx.  Is that the issue?  If so, can I fix it by changing the name of the folder back to the name of the aprx?
DanPatterson
projects don't necessarily get the name of the aprx, but if you remember what the original folder was then try that.  The *.gdb and toolbox will located there as well
LaraOles1
Yes, it had to do with changing the folder name.  Thanks for your help!
