ArcGIS Pro freezes when using keyboard shortcuts
4455
14
05-11-2024 08:55 AM
SK2438
Every time I try to copy and paste an object in a layout the app freezes.  If I wait long enough (about 20-30 secs) it will eventually copy the object and I can continue working.  I am not copying large, complex objects.  These are small and simple objects like generic text, callouts, etc.  Seems like a bug in the software.  I am using ver. 3.2.2.
MikeBosko
Same issue, still....  not always, but when it starts....
michelle-maps
I have the same issue. Using v3.5.2. It freezes when using the copy keyboard shortcut or when right-clicking and copying a layer view the pop-up menu.
SarahEason1
Not just layouts; layers, attribute table values, records in attribute table, fields from fields view. Not just control C but also right click, copy (although so happy Pro added this since it didn't used to) AND from clipboard on the ribbon.  Looking forward to this fix for ArcGIS Slo 🙂
AdamRehn
I have the same issue - ArcGIS Pro 3.5.0
JPrescott
I have been experiencing the same issue, in Win11 Pro 3.6.2 (newly upgraded).  As soon as I ctrl-C and ctrl-V to copy paste a feature, the feature does copy, but the UI loses critical functionality.  I can no longer pan the map with the mouse (although I can still zoom with wheel), I can't perform any action in the map that involves click-and-drag, such as move a feature or rotate a feature.  And when I exit the application later, a brief message appears saying "copying feature" just before the application closes.
