ArcGIS Pro freezes/crashes when adding a legend
5516
12-04-2020 02:53 AM
by Anonymous User
Not applicable
I'm using ArcGIS Pro version 2.4.0 and virtually every time I attempt to adda legend to my layout, it causes the program to crash. I draw a box with the tool but when I let go of the mouse, no legend appears, the drawing tool remains and I can't interact with ArcGIS Pro at all. I have to kill the program from Task Manager. At this point it's so frequent that I always save right before adding the legend so I can try adding the legend and then just open it up again once it has crashed. What I find especially strange is that it never crashes when I boot it back up again. Any thoughts on what might be causing it?
Tags (4)
2 Solutions
DanPatterson
MVP Esteemed Contributor
It it is happening all projects and you have cleared your caches you might want to try an upgrade of Pro or try a repair of the software (Add/remove programs, remove, repair)
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
One thing that I see in the internal reports is a GeoSoft Plug-in (ntdll.dll) will cause the issue.  If you have this plug-in, uninstall it and try your workflow again.  Another thing to try is perform a repair install.  Open the Control Panel>Programs and Features, right-click on ArcGIS Pro and select "Uninstall/Change", and select Repair and run the installation.  That might fix it too.  Good luck!
DanPatterson
Robert_LeClair
by Anonymous User
Not applicable
Thank you both for your responses. I cleared my cache to no effect but upgrading to the latest version of ArcGIS Pro seems to have solved the issue, thankfully.
Bio_GIS
I'm experiencing this same issue, although it appears to be specific to one hosted feature layer.
ArcGIS Pro is up-to-date, ran the repair option in Install/Uninstall, cache is cleared, and I do not see the GeoSoft Plug-in (ntdll.dll) or I would've removed that as well in regards to what was recommended above.  I can replicate this issue on two separate PCs.
As a workaround, I isolated the data I needed, exported it to a geodatabase, reimported it and made my maps.
Any suggestions?
Robert_LeClair
If you're the owner of the hosted feature layer, I'd recommend deleting it and republishing it to the online portal in which it resides.  What is the result?
