ArcGIS Pro failed
3669
6
03-27-2019 01:01 PM
SeanMather1
What is error code 1618?
15:53:55: ERROR Upgrade failed on: ArcGIS Pro
15:53:55: Upgrade operation canceled.
15:53:55: MSIInstallProduct failed: error code = 1618
15:51:14: Attempting to upgrade product: ArcGIS Pro
15:51:14: Killing satellite process.
15:51:06: Wating for ArcGISPro process to exit...
15:51:06: Found process to terminate.
15:51:06: Searching for running processes within the update folder.
15:51:06: MSI file version: 2.3.15769
15:51:06: Existing installation detected.
JoeBorgione
SeanMather1
Still Failed.
Sean Mather
GIS Analyst
American Forest Management, Inc.
We’re in this together®
8702 Red Oak Blvd., Suite C
Charlotte, North Carolina 28217
Direct: 704.527.6780 Ext.335
Fax: 704.527.1245
americanforestmanagement.com
JoeBorgione
Probably time to call ESRI tech support...
That should just about do it....
DanielUrbach
Sean,
The 1618 error code, in my experience, can be triggered if Windows updates are taking place, so you might check that too.
If you have not done so already, I recommend rebooting the machine too, as there may have been another installation that got hung but is causing Windows to block other installations from taking place.
Also check with your IT department, as they may have automated updates pushed out to your machine that were in the process of installing when you tried to install Pro.
-Danny
SeanMather1
Sounds like when I have time, I need to uninstall Pro and reinstall it.
Sean Mather
GIS Analyst
Fax: 704.527.1245
AlexStevenson
This particular case (other installation in the background) has happened to me several times.  I would first recommend a reboot and try to reinstall.
