ArcGIS Pro Export to PDF Stalling Layers with Transparency?
2798
01-03-2018 02:31 PM
KalenMyers
Hi there,
I'm having consistent issues with my PDF products after using Export to PDF with ArcGIS Pro. I think I've narrowed it to layers that have transparency set. Basically, when I export to PDF and first open the document it appears as if certain map layers haven't drawn (those with transparency of some level). If I resize the PDF, scroll to the next page, or even minimize the document and re-open it, the layers appear. It's like the drawing of those items is stalled until I make some sort of action to the Adobe application.
I don't have this issue when I print the layout as a PDF, but the quality is a lot worse than when exporting.
Has anyone else had this issue? Suggestions?
JaneSchafer-Kramer
I am having the same problem. Have you resolved this yet?
KalenMyers
Hi Jane,
Unfortunately not. This is still a mystery. I'm avoiding transparency whenever possible.
DalindaDamm
For clarity sake, does the product export without issue - you only have a problem when trying to view it?
I was testing the export of an EPS file out of ArcGIS Pro and had issues with the application crashing during the export. I was able to isolate the issue in that particular project/map to the existence of a layer with transparency applied. I am wondering if there is a connection between the PDF issue described in the original post here and this situation I faced...
Kyle_LocGov
Does anyone know the solution yet? Would purchasing the Production Mapping license solve it?
