Using 2.9.3. I set up field alias names from the Contents pane through Data Design/Fields When I look at the same layer in the Catalog pane and go to Data Design/Fields, the aliases are blank.
When I first open the Field design from the Contents pane and then open it via the Catalog pane, the selected tab stays the same but the contents of the tab changes.
Shouldn't the contents of the view be the same and the aliases entered appear in both?
Via the Contents Pane
Via the Catalog pane
Are you loading a new or old APRX for this project?
Thanks for the question. It's a 2.9.3 aprx. I just created a new aprx with 2.9.3 and a new fgdb and new layer and same thing happens. I tried refreshing the layer in Catalog and closing and opening Pro and the alias in the Data Design/Fields are blank as shown in the screens in the first post.
This same behavior occurs in Pro 3.0.0. Is one set of aliases stored in the map and the other stored in the fgdb? Doesn’t make sense to me.
I am running into this situation in Pro 3.0.3. Super confusing. It would seem that you can configure fields, via the layer list, separately from the source feature class in a file geodatabase. I have been using Pro for a long time but didn't know that this happens. I need the source data to have my field configurations, so now I have to re-do a lot of work. I am really unhappy with this. It would help if Esri displayed a message when you go to configure fields via the layer list, saying that these configurations will not be made to the source data. Very frustrating.
For future reference, your related post: Warn user when configuring fields via layer list
A layer and a feature class are two distinct concepts. A layer is a reference to a feature class. Layers in a map are configured independently of the data that they reference. These two concepts are intentionally disconnected since the data source can be used in many maps and projects simultaneously. If layer settings propagated to the data source, or vice versa, it would not be possible to use a single dataset in multiple maps or layers, without the configurations changing in all maps, every time someone made an edit to their individual maps.
If you are looking to edit the schema of the data itself, you can either open the fields view from the data source in the catalog, or, if you prefer entering the fields view through the layer in the TOC, you can configure the data source by selecting 'Data Source' in the 'Current Layer' drop down.
