Arcgis Pro Crashing While Trying to Create Features
1209
02-11-2025 12:09 PM
ShelbyMyers
Hello, I have been using Arcgis Pro version 3.4 for a while now with no issues, but recently when I go to create a new feature, the program completely freezes then utlimately crashes. There's no crash report that appears when it does this, so I'm not sure what to do or why it's happening. I can edit the same map and feature layers in Arcgis Online with no issues, just the one specific project in Arcgis Pro is doing this. Any suggestions? Thanks!
Tags (1)
Robert_LeClair
Esri Esteemed Contributor
Does the error/crash occur in a project that is saved to an *.aprx?  If so, can you test the Create Features workflow in a brand new, not saved project?   Does ArcGIS Pro still crash?
ShelbyMyers
Hi Robert, yes it's saved to an .aprx, it's part of the Stormwater Managment Solution. I tried creating features on another new project and it works fine (even the other maps in the same solution), just this project has this issue. I found it's only when creating a feature, editing is completely fine and everything is updating properly from the other maps. I'm trying to think back what might have caused this, but I'm not sure, thanks.
Robert_LeClair
Hmmm...sounds like a corrupt *.aprx then.  If that's the case, then there's no solution other than to create a new *.aprx for future work.
