ArcGIS Pro crashes on authentication
1981
10-29-2023 11:45 PM
CateRyan
Hi, when I try to log in to ArcGIS Pro the system crashes on authentication, with no error message. I've checkes Task Manager and it's not running in the background. I'm running version 3.03 on my desktop. I have tried restarting, clearing cookies, trying on multiple machines, no luck. I even got someone to try to log in on my machine with their account, no luck. What could be wrong?
Robert_LeClair
Esri Esteemed Contributor
Sometimes there are Add-Ins that cause ArcGIS Pro to crash on startup.
Run the following from a command line to start ArcGIS Pro without add-ins:
"%ProgramFiles%\ArcGIS\Pro\bin\ArcGISPro.exe" /disableaddins
If a problem is resolved when add-ins are disabled, it indicates that the problem is caused by an add-in located in a well-known folder on your machine or on a shared network.
CateRyan
Thanks Robert, unfortunately that didn't work. I've also tried all of these things: https://support.esri.com/en-us/knowledge-base/problem-arcgis-pro-stops-responding-after-login-000013.... The only thing I can think of is that the last time I logged in was Oct 25, when there was a new AGOL update (although I can log into the online version ok).
Robert_LeClair
Certainly.  I wonder if Esri Support Services needs to reset your ArcGIS Pro licenses perhaps?  Might be worth a call to Support Services.
BrookeRadding
Login through a browser window rather than through the app. Worked for me!
