This morning I awoke to several users saying that ArcGIS Pro will not open. It crashes immediately at the "Initializing..." point of the splash screen. Windows update ran on all 3 machines last night, see those updates below.
I have confirmed on a machine that did not receive these updates that ArcGIS Pro is still running correctly, so I would assume that rules out any issues with our License Manager.
Has anyone else experienced this today?
Solved! Go to Solution.
Analysis of the crash dump generated shows the crash is indeed WPF related and is a TypeInitializationException as Microsoft's makes in their statement.
Thanks Randall.
I'm going to try workaround 3 to solve this problem but I have to obtain admin permission to do this first. It would be great if Esri could provide a built-in solution soon.
Workaround 3 - Replace GlobalUserInterface.CompositeFont
Replace corrupted font file with correct version.
Download GlobalUserInterface.CompositeFont (default download for Windows 7 is %USERPROFILE%\Downloads).
Open cmd
and navigate to %windir%\Microsoft.NET\Framework\v4.0.30319\WPF\Fonts and run:xcopy /y %USERPROFILE%\Downloads\GlobalUserInterface.CompositeFont .
(or copy and paste the GlobalUserInterface.Composite file through Windows Explorer to %windir%\Microsoft.NET\Framework64\v4.0.30319\WPF\Fonts)
Open cmd
and navigate to %windir%\Microsoft.NET\Framework64\v4.0.30319\WPF\Fonts and run:xcopy /y %USERPROFILE%\Downloads\GlobalUserInterface.CompositeFont .
(or copy and paste the GlobalUserInterface.Composite file through Windows Explorer to %windir%\Microsoft.NET\Framework64\v4.0.30319\WPF\Fonts).
Re-launch WPF application.
Reboot machine and re-launch application if you still have trouble.
Does this issue only impact Windows 7 machines and not Windows 10 machines?
I suspect so. That was the case when this happened with v 1.3.
I'm running Windows 7 SP1. Are you having a similar problem in Windows 10?
I'm just trying to be pro-active as my org will probably only utilize Pro on Windows 10 machines, so if it only occurs on Windows 7 then I should be good to go (Although my org usually tests Windows Updates on a test machine to check for bugs before releasing Windows updates to general users).
I would follow Microsoft's advice and avoid installing the bad patch until Microsoft releases an updated version. Microsoft states:
Please avoid installing this update on Windows 7 or Windows Server 2008 R2
Like so many other things on my machine, this is out of my control. The update was installed as a matter of course by IT and I probably won't convince them to uninstall it. GIS folk are the poop disturbers according to most IT departments... Until then it's back to ArcMap for me.
Would anyone know if this Windows update has the same negative impact on Pro in Windows 7 if you have the latest Pro 2.1 version installed?
Yes it does seem to affect Pro 2.1 as well, I saw the crash in Pro 2.0 and then thought perhaps the upgrade would help. It did not, same crash in 2.1.
I encountered the same crash today with these CPU specs:
- Windows 7 SP1 64-bit
- .NET Compact Framework 2.0 SP2 and 3.5
- .NET Framework 4.7.1
- Recent MS updates KB3186497, KB4033342, KB4055532
