ArcGIS Pro Catalog Pane view two same folders and cannot refresh
1932
03-20-2024 08:51 AM
DEAF_PROBERT_68
Honored Contributor
I am curious about the strange thing I am seeing sometimes but want to hear others...
So when you are in ArcGIS Pro in the VDI environment and you are in the ArcGIS Catalog had two similar names  that looks like this :
Could someone tell me why does it read like that ?  I tried to refresh and it does not work
Robert_LeClair
Esri Esteemed Contributor
So a couple things that could be causing this behavior:
1. BUG-000140485 - Duplicate folders are created when saving a project name containing a comma to a file location that is also named with a comma.
2.  Esri Community Posts that reference this:  Solved: Geodatabse 'ghost' feature dataset and feature lay... - Esri Community and Solved: Feature Datasets and Classes Appear Twice in Catal... - Esri Community
Hope this helps!
Robert_LeClair
Hope this helps!
DEAF_PROBERT_68
Honored Contributor
I see !!1 Thank you, Robert !
Robert_LeClair
You bet!  If you feel my answer resolved the question, please mark it as "Accept as Solution" to close out this thread.  All the best!
