ArcGIS Pro Calculate Field (using SQL) Not Honoring Selection
6817
10
03-27-2019 01:41 PM
KyleBalke__GISP
It appears that the Calculate Field tool when using the SQL expression type in ArcGIS Pro 2.3.1 does not honor a selection set.  Is this functionality not supported or this a bug?  I could not find any mention of this in the ArcGIS Pro help.
PaulHoefflerGISS
I ran into this last night, one in a series of problems when trying to join a table to an ArcGIS Online hosted feature layer and then calculate a field.
This is good information.
It would be even better if an invalid option was not displayed when the inputs contain an unsupported format, instead of as a note in the online documentation.
Python 3 worked for this particular issue.
Thanks for the info, as always!
