ArcGIS PRO bug with Tables and Time Slider?
8908
11
08-29-2023 12:48 AM
PaoloBasile_ST
Hi all,
in an ArcGIS PRO project I set up two Layers (Feature Layer and Standalone Table) with two start and end date fields.
I then used Enabled Time to filter the layers by date.
I noticed that the Feature Layer is filtered correctly while the Standalone Table is not.
Is there something I am doing wrong or is there a bug in ArcGIS PRO?
I attach two images with the settings of the Standalone Table and the result of the filtering (or rather the non-filtering).
Thanks!
PaoloBasile_ST
Yes, it is set (I had not noytated it as an option but it is set).
Paolo
AlyciaRajendran_esri
Well this is confusing for me! Are you able to contact Support? There may be a bug somewhere and it'd be hard to figure it out in this thread. Thanks!
