ArcGIS Pro 3.5 and Deep Learning Libraries
3125
05-13-2025 12:44 PM
Ed_
by MVP Regular Contributor
Recently saw the notification for Pro 3.5 and it has some neat new features.
Issue is that the Deep Learning libraries installer is not available on Github for 3.5. Right now, I am on 3.4.3 so, will those libraries work for Pro 3.5 as well?
Question | Analyze | Visualize
DanPatterson
MVP Esteemed Contributor
From the documentation
Each version of ArcGIS Pro requires specific versions of deep learning libraries. When you upgrade ArcGIS Pro, you need to install the deep learning libraries that correspond to that version of ArcGIS Pro. For the list of libraries required at each version along with other information, see Deep learning frequently asked questions.
The libraries lag by a "bit" after a release, so if it is a must, you will have to compare the packages and see if any of the pinned ones are going to cause you an issue.
Just monitor Issues and Pull requests on
Issues · Esri/deep-learning-frameworks
the last mention of the libraries was for 3.5 Beta in April, so I am sure it is coming.
In a pinch... be the first to see if the 3.4 libraries fail in 3.5
... sort of retired...
DanPatterson
WilliamTarpai
Thanks @DanPatterson    Very pleased with your well timed response.   Allow me to provide some deep reading about the value of libraries - Libraries for Sustainable Development
Sustainable Development Goal 4 - Target 4.7. reads: “By 2030, ensure all learners acquire knowledge and skills needed to promote sustainable development, including among others through education for sustainable development and sustainable lifestyles, human rights, gender equality, promotion of a culture of peace and non-violence, global citizenship, and appreciation of cultural diversity and of culture’s contribution to sustainable development.”
Tags (1)
