ArcGIS Pro 3.0.2: How to get the text description of a symbol in one line in the legend?
936
05-24-2024 10:16 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, I couldn’t figure out how to get the text description of a symbol in one line in the legend
The data is attached
Jamal Numan
RonaldHaug
MVP
Hi Jamal,
Good to see your post. I've been away for a month and just now return to esri community.
I like your problem because it's an easy one to remedy, and a great way to get back into meddling in other people's problems.
Right click on Legend, and select properties.
Then go to Legend arrangement options.
On word wrapping, increase labels or descriptions to your desired width.
Then close out of the element pane and save project.
You may have to mess with this a bit and also increase your legend window size to get it just so.
Let us know how you did with a picture of your result, Jamal!
RonaldHaug
MVP
Hi Jamal,
JamalNUMAN
Many thanks for the help, Ronald. It works fine as per the screenshot below
Jamal Numan
