ArcGIS Pro 2.9.5 crashes when using Trace tool in Python script
1424
02-09-2023 11:37 PM
MaryamBarzegar
Hi, after the new update of windows, I had issues with symbology and I upgraded to 2.9.5 and symbology was fixed but when I use trace tool in my Python script, ArcGIS Pro crashes. I've tried different versions, 2.9.6, 2.9,2.9.2 all of them crash, and I tried choosing OpenGL for display options, still the same. How can I fix this?
MichaelVolz
Esteemed Contributor
At what version of Pro did the Trace tool work for you in a python script?
Have you tried to upgrade to Pro 3.0.3 to see if that fixes the issue?
MaryamBarzegar
I can't recall which version was ok before installing 2.9.5. I tried 3.0.3 as well, same thing happened, it crashes.
MaryamBarzegar
I think I need to explain it more, it happens with the "Network layer" output option and it works using the tool but when I copy the python command of the tool and use it in a Notebook, it crashes. I tried with other output types like selection, and it didn't crash in Python script.
