ArcGIS Pro 2.9.2 unable to install Spyder
5710
18
04-09-2022 09:06 AM
MarkBinder
I have upgraded to ArcGIS Pro 2.9.2 but I am having trouble installing Spyder and managing my virtual environments.
When I clone a virtual environment it does not appear on the list of environments in ArcGIS Pro; if I add it, close and then re-open ArcGIS Pro it still does not appear on the list.
When a cloned environment does appear on the list and I try to install Spyder it appears to go through the installation but in the end nothing is installed.
How can I get Spyder installed?
Tags (3)
MichaelAugust
can you elaborate on what the issue is exactly?
MarkBinder
I think the other posts explain everything. Basically trying to clone the 2.9.2 Python environment was not working.
MichaelAugust
Ah ok, I am able to clone my environment, but then Spyder would install, but not install. I get prompted to accept terms, hit install, but it never finishes, or shows up in installed packages. So a slightly different problem I guess...
MarkBinder
That sounds like what mine was doing. Did you try installing with command line?
DanPatterson
MVP Esteemed Contributor
activate your environment then
conda install spyder --no-pin
If you want to see what might happen add --dry-run to the end of the line for testing purposes
... sort of retired...
MichaelAugust
Hi Dan - well that --no-pin option got Spyder installed, after multiple installs/downgrades/upgrades, (looks like mostly to the machine learning packages) - but when I launch it - it chokes on import arcpy, import numpy, kernel is spinning and crashes in windows...
and I found this at Spyder repo...and I found this at Spyder repo...
DanPatterson
Ahhhh well, I install spyder in the base environment, I don't use clones.
by Anonymous User
Not applicable
Does ESRI plan to fix this issue with 2.9x? It is extremely annoying and my organization only has access to 2.9x. I've been working with our internal help desk on this but was basically told I have to wait until we are allowed to use Pro 3.x
Has anyone discovered a workaround?
JasonBarker
I was having same problem as described above. I axed the problem clone and reinstalled Pro. I was then able to get Spyder to work in my new ArcProg 2.9.1 py3 clone via:
conda install Spyder.
