ArcGIS Pro 2.9.2 - How to print messages in View Details dialog box when using Code Block in Calculate Field?
856
04-13-2022 01:00 AM
VincentLaunstorfer
As everybody, I use Calculate Field regularly in ArcGIS Pro.
I wonder if it is possible to print messages in the Code Block section. I used the print() statment and the syntax is correct. After running the Calculate Field tool, if I click on the View Details, I cannot see the print messages I wished. This is purely informative and this helps to understand the calculation in details...
Any guess?
Luke_Pinner
MVP Regular Contributor
Have never tried, but perhaps:
arcpy.AddMessage("your message")
VincentLaunstorfer
Thanks Luke.
I already tried the arcpy.AddMessage() but this one does not work in Code Block...
JamesWilcox1970
Would a combination of arcpy.AddMessage and arcpy.GetMessages work?
