ArcGIS Pro 2.8.4: The Python If statement fails to work,
1444
06-27-2022 10:10 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, I wanted to apply a simple if statement but fails to work and ends up with an error
def Reclass(Confinement):
    if Confinement == Confined:
        return 1500
    return 0
What could be the issue here?
The data is attached
Jamal Numan
JayantaPoddar
Code Block:
    if Confinement == 'Confined':
        return 1500
    else:
        return 0
Think Location
DanPatterson
MVP Esteemed Contributor
 Confinement == "Confined"
and it should be, with a python parser
Reclass(!Confinement!)
to invoke it.  Note the enclosing ! marks
... sort of retired...
JayantaPoddar
Code Block:
        return 1500
    else:
        return 0
Think Location
JamalNUMAN
Thank you JayantaPoddar for the help. It works fine
        return 1500
    else:
        return 0
Jamal Numan
