ArcGIS Pro 2.8.1 Editor Tracking is broken
2176
07-08-2021 09:18 AM
RyanTucker
Edit: Just got off the horn with ESRI Tech support. This is a known bug.
I try to enable editor tracking on only the editor name and edit date fields on my feature classes in a file geodatabase, I don't want creator fields. However ArcGIS Pro 2.8.1 keeps setting the fields I select for Editor and Edit date  as the Creator and Creation date fields. Works just fine in ArcCatalog 10.5.1 when I set the editor tracking there.. It also used to work just fine in ArcGIS Pro. This has to be a bug. Any thoughts?
RyanTucker
Thanks. But support has this behavior listed as a bug; BUG-000140962
ABishop
RyanTucker
ChristopherBowering
Hi Ryan - could you please copy/paste the bug description?  I'm experiencing something similar and am curious as to how they describe the bug.  In my case, I ONLY want a 'Created Date Field' yet when I enable editor tracking, the automatically created 'created_date' field gets bumped up into the 'Creator Field' space with the field type being text.  I had to use both the Creator and Create Date options to get the date to function properly despite not needing/wanting the Creator.
RyanTucker
Christopher,
here it is:
BUG-000140962 Editor tracking assigns editor fields for the creator category when the creator has been set to None
