ArcGIS Pro 2.6 Select Tools Don't Dock
2163
09-02-2020 09:40 AM
JoeBorgione
Is this expected behavior?  In past versions, the Select by Attributes and the Select by Location tools docked.This is 2.6:
Here it is in 2.5.1:
Kory Kramer
That should just about do it....
KoryKramer
Esri Esteemed Contributor
Hi Joe,
Yes, that is expected at 2.6.  See the what's new doc What's new in ArcGIS Pro 2.6—ArcGIS Pro | Documentation
Find a geoprocessing tool—ArcGIS Pro | Documentation
So the floating window can't be docked, but you can always run GP tools the "normal" way through the gp pane - You just don't get the benefits of running in the floating window.
DanPatterson
MVP Esteemed Contributor
I always have the Geoprocessing tab docked to the right of the map, then put my frequently used tools there instead of using the ribbon.  The tools open up there without any further need for docking
... sort of retired...
JoeBorgione
Hmmm...  thanks!
KoryKramer
Hi Joe,
JoeBorgione
Thanks Kory Kramer!
