ArcGIS Pro 2.6: How to perform “relationship class” with many to many (M:N) option?
I couldn’t figure out how to perform “relationship class” with many to many (M:N) option
For example, I wanted to relate the attribute of feature class below with a standalone-table via ID_L1 and ID_L1_T fields respectively.
Then what I’m supposed to fill in the origin primary key, origin foreign key, destination primary key, and destination foreign key?
From
Create Relationship Class (Data Management)—ArcGIS Pro | Documentation
origin_primary_key | The field in the origin table, typically the OID field, that links it to the Origin Foreign Key field in the relationship class table. | String |
origin_foreign_key | The field in the relationship class table that links it to the Origin Primary Key field in the origin table. | String |
destination_primary_key (Optional) | The field in the destination table, typically the OID field, that links it to the Destination Foreign Key field in the relationship class table. | String |
destination_foreign_key (Optional) | The field in the relationship class table that links it to the Destination Primary Key field in the destination table. | String |
and many-to-many cardinality... you will have to figure out your origin and relationship class tables and select the appropriate fields. There are only a few combinations that you can try... what did you try?
Here is how I set up a M:N relationship using the Table to Relationship Class geoprocessing tool. This ties together the Management Regions features to the Source table using the Region_Source relationship table.
Thanks Ken for sharing concrete example in how to perform M:N relationship
In the screenshot below, the “table to relationship class” is performed, however, identifying features returns nothing
What could be the issue here?
In the Layer Properties dialog, do you see the relate?
Thanks Ken. It appears to work fine with the “table to relationship class” tool.
But how to work with “create relationship class” tool?
Most, if not all, of the parameters should be the same as in the Table to Relationship Class tool. Have you read this documentation?
Thanks KenBuja.
I have read the documentation but unfortunately there is no concrete example in how to perform the tool
