ArcGIS Pro 2.6: How to identify which band is which?
1638
08-17-2020 03:10 AM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, the raster has 4 bands. How to identify which band is blue, red, green, infrared, etc.?
Jamal Numan
DanPatterson
NDVI—ArcGIS Pro | Documentation
raster
The input raster.
Raster
nir_band_id
The band ID of the near-infrared band. The ID index uses one-based indexing.
(The default value is 4)
Integer
red_band_id
The band ID of the red-edge band. The ID index uses one-based indexing.
(The default value is 3)
So unless you have changed how the rasters are ordered, then by convention, nir would be 4 and red would be 3
... sort of retired...
JamalNUMAN
Thanks Dan.
As bands are labeled with band#0, band#1, band#2 & band#3, then is it assumed that they are equivalent to band#1, band#2, band#3 & band#4 respectively?
Is there any other way to check which is which so that we can make sure that (in my raster):
band#2 = Red
band#3= Infrared
Jamal Numan
DanPatterson
There is no band 0 in remote sensing, that image is just showing 0-based numbering... so add 1 to get your bands
JamalNUMAN
But what the values of RGB represent in the screenshot below?
Jamal Numan
