ArcGIS Pro 2.6.2: A feature class fails to display and “project” tool ends up with error,
700
10-25-2020 03:04 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, despite the fact that the attribute table of feature class has records, in addition to the fact that the “project” tool ends up with error.
What could be the issue here?
The feature class is attached
Jamal Numan
DanPatterson
MVP Esteemed Contributor
It was defined wrong.
It was defined as a geographic coordinate system when in fact it was already in your desired projected coordinate system.
"Define" it appropriately, then use the Add Geometry Attributes tool to confirm the area and centroid values.
... sort of retired...
DanPatterson
JamalNUMAN
Many thanks Dan. It works fine
Jamal Numan
