ArcGIS Pro 2.5: How to label features based on two fields with each label on a separate line?
19448
13
02-28-2020 10:50 AM
JamalNUMAN
Legendary Contributor
ArcGIS Pro 2.5: How to label features based on two fields?
For example, in ArcMap features can be labeled based on two fields such that labels can aligned vertically by using the expression below:
[Male]  & vbnewline & [Female]
How this can be performed in Pro?
Jamal Numan
HamedFarzin
Resources for labels in ArcGIS Pro:
Specify text for labels—ArcGIS Pro | Documentation
KoryKramer
Esri Esteemed Contributor
Jamal NUMAN‌ please remember to close out your question by marking what you think is the best answer as Correct. (This goes for any of open questions...) This will help other community members find solutions more quickly.  Thanks!
JamalNUMAN
With the vbscript language option, the Pro does take the table number formats to the label as it is used to work in ArcMap.
Jamal Numan
JamalNUMAN
Example:
Text($feature.Density, '#.###') + TextFormatting.NewLine + $feature.EACode
Jamal Numan
