It seems as though the Date Modified is not showing for individual layers within a database or maps. Just using databases as an example, as you can see, I get the date modified for the databases, but not the layers. There's not many options besides just checking the box for 'More Details'. Anyone else having this problem? Is there something I'm missing??
Solved! Go to Solution.
Date is currently not returned for feature classes. Please see this idea to vote and comment.
https://community.esri.com/ideas/14937-add-additional-details-in-catalog-view-in-arcgis-pro
Thank you.
Did you ever find the answer to this? It's driving me CRAZY!
Thank you.
Thanks Kory, I've voted on this. I don't see this so much as an 'idea' though...it should just be part of the functionality of the software shouldn't it?
Going to throw out there that this is a bug not a feature request / idea and the old line of this is a feature / limitation not a bug. The value is:
- populated in geodatabase
- shows in ArcCatalog (the faster more reliable on ethat comes with ArcGIS for Desktop
- Main thing that bumps this to a bug IMO is Catalog view in ArcGIS Pro has a column for this value just doesn't show it.
Given that can Kory Kramer confirm if there's a bug logged for this? Or can it be upped from an idea to a bug.
Cheers,
Sam
There is an internal issue logged as [ENH-000120865: No date modified field is provided in ArcGIS Pro on a feature class in the Catalog window.] that is linked to https://community.esri.com/ideas/14937
