ArcGIS Pro 2.2.0 and Python Package Manager
64524
112
06-27-2018 11:00 AM
MitchHolley1
I updated to Pro 2.2.0 today and noticed the default python environment is now read-only.  The previously downloaded packages I had were wiped out with the new update.  I need to get the package, spyder, back into my environment.  So, I cloned the arcgispro-py3 environment in order to make the install.
Notice that the window says, "Restart ArcGIS Pro for your environment changes to take effect."
So, I clicked 'Exit'.
After the program restarted, I no longer have a cloned environment to select.
Can someone please help?
DanPatterson_Retired
Your potential update is quite significant.  I have Spyder installed as my python IDE so that accounts for only a few of your upgrades and the ArcGIS accounts for some more.
/blogs/dan_patterson/2018/12/13/spyder
and some clone stuff
/blogs/dan_patterson/2018/12/28/clone
What are you using for python?
I wouldn't install via pip let conda manage things.
You could give it a go, but I would have the ArcGIS pro install *.exe or at least the *.msi and *.cab file on hand incase you have to do a complete reinstall
You might want to start a new thread if you have issues..
NicholeSalinger
took a few tries but ....
arcgispro-py3 conda install tensorflow
