ArcGIS Pro 2.1 Crashes Computer
2872
01-24-2018 05:12 AM
JustinFuto1
I upgraded to ArcGIS Pro 2.1 the day after it released and have experienced multiple unexpected crashes of my PC.  The majority of the time I was changing symbology of a feature class in SDE and all of the sudden Pro freezes and shows not responding then my entire computer freezes up.  After I forced my computer to shutdown I created a new project (thinking the project might be corrupted like how mxd's get corrupted) and began adding my feature classes back to the map.  I began changing the symbology and labeling features then my PC locks up again.  The other times it's done this has been adding a title to a layout and adding a legend.    Unfortunately, an error log was not generated for either of these instances because I had to do a force shutdown.
Anyone else experiencing this issue?
System Information:
HP ProDesk 600 G3 MT
Intel Core i5 @ 3.4 GHz
16 GB RAM
Nvidia GeForce GTX 1050 Ti
Windows 10 Version 1709 Build 16299.125
I'll add that after upgrading to Pro 2.1 and experiencing all of the crashes I went back to 2.0 and I've experienced the same crash when modifying symbology, just not as frequently as I did when using Pro 2.1.
George_Thompson
Esri Notable Contributor
Hi Justin Futo‌ it looks like you may be encountering a known issue. Someone posted this on your questions in this thread: https://community.esri.com/message/743363-re-arcgis-pro-crash-suspected-windows-update?commentID=743...
BUG-000110910:  Pro for ArcGIS crashes when symbolizing SDE data
I would recommend getting a new case opened with https://community.esri.com/groups/technical-support?sr=search&searchId=6318ae6d-5cee-463c-8559-2ab15...‌ and have them verify the issue and steps. Hope that helps!
--- George T.
MichaelVolz
Esteemed Contributor
Justin:
Does Pro 2.1 crash if you change the symbology of a feature class that is sourced from a file geodatabase instead of an SDE database?
JustinFuto1
It doesn't seem to matter if I'm using feature classes from a file geodatabase or an SDE database.  Also crashes when I'm adding a legend, text element, etc in the layout.
