ArcGIS Pro 2.0 | How to design Fields in shapefile from Catalog Pane ?
3066
14
01-26-2018 08:05 AM
VincentLaunstorfer
Just a simple question. From the Catalog Pane, if I right-click a shapefile -> Design -> Fields, I can view the fields but cannot edit them, such as making a field Nullable for example.
All the fields are greyed out!
Morever, I made these fields with the ModelBuilder Add Field with a variable set to IsNullable (as the option is not included in the Add Field right-click settings in ModelBuilder)
Finally, if I use Delete Fields (as below), these fields still show up in the Field design pane! As a result, the ModelBuilder crash because it considers these fields still existing...
I am puzzled and I suspect ArcGIS Pro do not refresh features classes after geoprocessing... If I restart, these fields do not show up and I can run the Model...
Any help appreciated
DanPatterson_Retired
I know this is from PRO, but it is the same in 'Map  see the code block
assuming your field is called that, field.isNullable
http://pro.arcgis.com/en/pro-app/arcpy/classes/field.htm
Test the field...
isNullable
(Read and Write)
Indicates if the field can contain null values.
VincentLaunstorfer
Just one last question, I cannot Calculate Field containing the silly ~ sign, such as in ALASKA~C. How can I improve my code to deal with these ~ signs?
don't know...
also, in your accepted answer, also add a check to see if the field is numeric since it will have to return 0 rather than ''... hence the suggested  'isNullable' check, because if it isn't nullable, then it already has the shapefile equivalent for None (aka '' for text and 0 for numbers)
VincentLaunstorfer
Thanks Dan. You're correct, I should check if the field is Numeric or Text in order to assign either 0 or ''. This would make the code more robust. Will investigate this soon...
Otherwise, Calculate Field with special character such as ~ did finally work with the code shown below (don't know waht happened yesterday!)
VincentLaunstorfer
Found the solution!
When there was a Null value in the joined table, the conditional statment could not "leave" a Null value in the shapefile. Instead, I inserted an else statment to return an empty value!
