ArcGis Online symbology to ArcGiS Pro
379
11-20-2024 06:15 AM
HafidaAttar
Hello everyone, I have a question regarding ArcGIS Pro. When I use the symbology format that was imported from ArcGIS Online, I can't display it correctly in ArcGIS Pro. The icons appear too pixelated, whereas when I check in ArcGIS Online, the icons appear correctly. Do you know if there is a solution to this? I don't want to recreate all the symbology in ArcGIS Pro as it would be a lot of work.
Thank you for your response.
ChristopherCounsell
MVP Frequent Contributor
Have you seen this technical article?
https://support.esri.com/en-us/knowledge-base/faq-is-it-possible-to-transfer-symbology-from-arcgis-o...
Doesn't look like a common workflow but it might be possible with the above method.
ShaneONeill_144
What symbology are you using? Do you have any screenshots of the issue?
