ArcGIS and other applications shows RGB 255,255,255 pixels as transparent after publishing as WMS
1168
08-29-2023 11:51 PM
Dannynld
Hi Community,
I'm new into ArcGIS and running into some trouble after publishing a map to WMS.
After publishing my map on WMS the map shows transparent pixels where the value of RGB is 255,255,255. This happens more when opening the WMS in other applications like QGIS than ArcGIS
Is there any fix for this? I guess its my lack of knowledge in this area.
Currently I'm using ArcGIS Pro 2.7 and ArcGIS server 10.9
In the photos under here I made some examples.
In this picture I opened the root file via a folder connection and the underlying layer is not showing in the RGB 255,255,255 pixels
Here I opened the WMS published layer in ArcGIS Pro and in some of the white pixels the underlying layer is showing up
WMS_QGIS.JPG In this picture I opened the WMS in QGIS and in more white (RGB 255,255,255) pixels the underlying layer is showing.
I guess I'm seeing something over my head. If anyone knows how to sole this I would be grateful
Kind regards,
Danny
SrinivasVinnakota
Open the layer properties in ArcGIS Pro (or QGIS) and make sure layer does not set a background color or make background color transparent. In ArcGIS Pro you will find this setting on the Display page of WMS layer properties.
