Arcade Script Working in some area and not working in some area
1291
01-09-2024 11:08 PM
HarishKV
@HusseinNasser2
I am using ArcGIS Pro Version 3.2, Enterprise 11.2 and Enterprise DB Postgres 15. I had ported all my data to enterprise db and added all the attribute rules and checked the output, which was working good in all the places. But when enabled branch versioning and published the feature layer these attribute rules working abnormally. At some geography its working good and some places not. Very different from enterprise db. Can you help me solve the issue.
Attribute rules used for the project also been added below for your reference. Appreciate your quick response, Since the issue faced in prod data.
1.PLOT ID:
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Village", ['taluk'], false);
var attributeName = 'taluk';
var intersectingFeatures = Intersects(intersectLayer, $feature);
var intersectedFeature = First(intersectingFeatures);
if (intersectedFeature == null) return 'NA';
var attributeValue = intersectedFeature[attributeName];
// Concatenate LBCode and the unique sequence number
var projectID = attributeValue;
return projectID;
2.PLOT AREA
var editingFeature = $feature;
var editingGeometry = Geometry(editingFeature);
var area = Area(editingGeometry);
var formattedArea = Round(area, 2);
return formattedArea
3.DISTRICT
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Localbody_Boundary", ['DISTRICT'], false);
var attributeName = 'DISTRICT';
return projectID;
4.TALUK
return projectID;
5.VILLAGE
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Village", ['village'], false);
var attributeName = 'village';
return projectID;
6.LOCALBODY
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Localbody_Boundary", ['LB_NAME_EN'], false);
var attributeName = 'LB_NAME_EN';
return projectID;
7.AIRPORT ZONE
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Airport_Zone", ['AIRPORTNAM'], false);
var attributeName = 'AIRPORTNAM';
return projectID;
8.ZONE COLOR
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Airport_Zone", ['zone_conct'], false);
var attributeName = 'zone_conct';
return projectID;
9.PERMISSIBLE HEIGHT
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Airport_Zone", ['permissibl'], false);
var attributeName = 'permissibl';
if (intersectedFeature == null) return '250';
return projectID;
10.NOC REQUIRED FROM AIRPORT
// Get the values of the fields you want to compare
var valueA = $feature.permissibl;
var valueB = $feature.Height;
// Perform the comparison and assign attribute value
var comparisonResult = IIf(valueA < valueB, "Yes", "No");
return comparisonResult;
11.RAILWAY ZONE
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Railway_Land");
var intersectingFeatures = Intersects(intersectLayer, editingGeometry);
if (Count(intersectingFeatures) > 0) {
return 'Yes';
} else {
return 'No';
12.DISTANCE FROM RAILWAY LAND
var Railway_lyr = FeatureSetByName($datastore, 'test_training.sde.Railway_Land');
var editingGeometry = Centroid(editingFeature);
var closestDistance = 999999999; // Set a large initial value
for (var Railway_feature in Railway_lyr) {
var dist = Distance(Railway_feature, editingFeature, 'meter');
if (dist < closestDistance) {
closestDistance = dist; // If the distance is < closest Distance, distance should be replaced with closest distance
var roundedDistance = Round(closestDistance, 2); // Round to 2 decimal places
roundedDistance; // This will return the rounded closest distance in meters
13.NOC REQUIRED FROM RAILWAY
var htl_lyr = FeatureSetByName($datastore, 'test_training.sde.Railway_Land');
for (var htl_feature in htl_lyr) {
var dist = Distance(htl_feature, editingFeature, 'meter');
if (roundedDistance < 30) {
return "Yes";
} else {
return "No";
14.CRZ ZONE NAME
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.CRZ_Boundary", ['name'], false);
var attributeName = 'name';
return projectID;
15.CRZ MAP NUMBER
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.CRZ_Map_Grid", ['map_no'], false);
var attributeName = 'map_no';
return projectID;
16.DISTANCE FROM HIGH TIDE LINE
var htl_lyr = FeatureSetByName($datastore, 'test_training.sde.High_Tide_Line');
17.DISTANCE FROM LANDSLIDE PRONE AREA
var htl_lyr = FeatureSetByName($datastore, 'test_training.sde.Landslide_Wayanad');
var buffer = Buffer(editingGeometry, 1, 'kilometers'); // Create a 1 km buffer around editing feature
var withinBuffer = false;
// Check if the feature is within the buffer
if (Intersects(htl_feature, buffer)) {
withinBuffer = true;
if (withinBuffer) {
} else {
"No landslide zone" // Return No intersecting zone with in 1km if editing feature is outside the 1 km buffer
18.DISTANCE FROM ELECTRIC TRANSMISSION LINE
var ETL_lyr = FeatureSetByName($datastore, 'test_training.sde.EHT_Lines');
var attributeName = 'KV_Type';
var closestDistance = 100; // Set a large initial value
var closestLineAttribute = null; // Initialize with null
for (var ETL_feature in ETL_lyr) {
var ETL_geometry = Geometry(ETL_feature);
var dist = Distance(ETL_geometry, editingGeometry, 'meters');
closestLineAttribute = ETL_feature[attributeName];
if (closestLineAttribute != null) {
return closestLineAttribute;
} else {
return 'No EHT line crossing below 100 meter buffer';
19. OFFICE LB CODE
var intersectLayer = FeatureSetByName($datastore, "test_training.sde.Localbody_Boundary", ['Office_LB_'], false);
var attributeName = 'Office_LB_';
return projectID;
20.DELETION RULE
$feature.is_required == 1;
if ($feature.is_required == 1) {
return {
'errorMessage': 'Deletion is not allowed for features with a value of 1 in ' + fieldName + '.'
} else {
// Allow deletion for other cases
return true;
21.CONSTRAIN RULE - AREA ACRE
var arealnSquareMeters = $feature.plot_area;
if (arealnSquareMeters > 121410) {
return {
'errorMessage' : 'Polygon area Must be 30 Acre of Less during creation.'
} else {
return true;
22.CONSTARIN RULE- OUTSIDE KERALA BOUNDARY
var aor = FeatureSetByName($datastore, "test_training.sde.Kerala_10M_Buffer")
return Count(Within($feature, aor)) > 0
I had created a workaround and now I am able to draw. But some fields returning "NA". Main Problem is with layers Village and LSGD Boundary. Only these layers returning NA result even though having boundary available in those geography
HarishKV
1.PLOT ID:
return projectID;
2.PLOT AREA
3.DISTRICT
return projectID;
4.TALUK
return projectID;
5.VILLAGE
return projectID;
6.LOCALBODY
return projectID;
7.AIRPORT ZONE
return projectID;
8.ZONE COLOR
return projectID;
return projectID;
11.RAILWAY ZONE
return 'Yes';
} else {
return 'No';
return "Yes";
} else {
return "No";
14.CRZ ZONE NAME
return projectID;
15.CRZ MAP NUMBER
return projectID;
if (withinBuffer) {
} else {
} else {
19. OFFICE LB CODE
return projectID;
20.DELETION RULE
return {
} else {
return true;
return {
} else {
return true;
HarishKV
Arcade scripts used for the project also been added for your reference.
