Tree canopy branch spread proportionate directional measurements
2438
01-05-2024 02:27 AM
Labels (2)
GIS_Ecologist
Good morning,
I am trying to produce a map for a tree survey in which I need to display the tree canopy with directional measurements.
I have looked at the proportionate sizing and it doesn't look to be the correct function. The image below shows what I am trying to achieve. The symbology needs to display a central point, along with 4 measurements from this central point.
Any ideas on how to achieve this would be very welcome.
JoannaWhittier
One option would be to convert the four points into a polygon and use the polygon in your map.
MervynLotter
MVP Regular Contributor
You should be able to change both size and rotation using the Vary Symbology By Attribute pane. See the attached image. In this screenshot I have used my GROUP field as input to rotation and SUBTYPE field as input to size.
GIS_Ecologist
Thank you both for the replies.
@JoannaWhittier The problem with using a polygon is that there is a central point and the canopy extends in a set distance in each direction from this central point.
@MervynLotter Can the size element be used to distort proportions of the symbol to show specific distance from a central point?
MervynLotter
If the point symbol being used is a distorted shape (so it is not perfectly round), then the rotation field can be used to rotate the symbol so that the distorted shape faces the direction you want.
