Arcade (or other) expression to create multi-line label with variable entries
4850
09-26-2022 03:27 AM
peterverwey_ses
Any help appreciated. I am trying to write an expression that will create a label based on presence or absence of data across a number of fields.
I want the label to include the following:
  • Location Name - from field
  • IF ItemCount != 0 THEN add a new line with a text label and then the ItemCount value ELSE go to next item
There are 9 or more items.
eg for the Home location with 2 cars, 4 bikes, and 1 boat the label would look like:
  • Car: 2
  • Bike: 4
  • Boat: 1
However, if no bikes or boat, then the label would be as below with no extra lines:
  • Car: 2
The data fields are setup similar to this
  • OID / LOCATION / CAR_count / BIKE_count / BOAT_count
Using Arcade I was able to build a multi-line label by using:
Concatenate([
  $feature.LOCATION,
  'Car: ' + $feature.CAR_count,
  'Bike: ' + $feature.BIKE_count,
  'Boat: ' + $featureBOAT_count],
  TextFormatting.NewLine)
This works fine and outputs a count for all 3 types even when the count is zero. I need to find a way to only add a line when the count is greater than zero. This will simplify the map by reducing the entries in the labels when only 1 or 2 of the 9 (or more) data fields are present.
The solution doesn't have to be using Arcade, could be VBscript, JScript, or Python if you have an easy solution.
Many thanks, Pete
jcarlson
Simple enough! We can use push to add entries to the array only when the condition is met.
var label_array = [$feature.LOCATION]
var counts = {
    'Car': $feature.CAR_count,
    'Bike': $feature.BIKE_count,
    'Boat': $feature.BOAT_count
for (var c in counts){
    if(counts[c]>0){
        Push(
            label_array,
            `\t${c}: ${counts[c]}`
return Concatenate(
    label_array,
    '\n'
And here's me testing that with some sample values:
- Josh Carlson
Kendall County GIS
jcarlson
var counts = {
    if(counts[c]>0){
        Push(
            label_array,
return Concatenate(
    label_array,
    '\n'
- Josh Carlson
Kendall County GIS
peterverwey_ses
Hi Josh,
You are a legend. Thank you.
Your solution worked first time and is simple and elegant. You have helped make a very messy map much cleaner and easier to read.
Can you suggest any good resources for learning more about arcade expressions like this?
Many thanks again.
Pete
jcarlson
You're very welcome!
I'd suggest a few things:
  1. Checking out the Arcade GitHub repo: https://github.com/Esri/arcade-expressions/
  2. Just messing around on the Arcade Playground: https://developers.arcgis.com/arcade/playground/
  3. Making a layer / map / dashboard that's specifically for just messing around with Arcade, and see what you can make with it.
- Josh Carlson
Kendall County GIS
