Arcade IsEmpty on empty array always returns False?
2816
07-28-2023 07:49 AM
Mark_Johnson
I'm working on an Arcade labeling expression in Arc Pro 3.0. If I enter only the code below, everything is labeled "0, false". Since nothing's been added to the array, I'm expecting IsEmpty to return "true". Am I thinking about this wrong, or is it maybe a bug?
var u = [];
return Count(u) + ", " + IsEmpty(u);
 Obviously I can use Count to check the array contents instead, but I've used IsEmpty in so many other places I just expected it to apply to arrays also.
KenBuja
MVP Esteemed Contributor
That's actually spelled out in the documentation
Returns false for all other cases, including empty arrays and dictionaries.
KenBuja
Mark_Johnson
Of course it was right there in front of my face and I still didn't see it 🙄 Thanks!
