Arcade function "distance" gives values below zeros
1622
04-03-2023 05:14 AM
Labels (3)
Hala_Ghareeb
Hi all,
I face an issue with Arcade in "Calculate Field"
I was trying to calculate the distance between two features, but it gives me numbers like: 3.06370662743992E-03, 2.1836948170503E-04, .... as in image(1)
after applying Floor (value, 4) it gives numbers like:0.0228, 0.003, .... as in image(2)
I want to have the distances in meters, and I am sure that all the distances are more than zero.
DanPatterson
Are you using a projected coordinate system?
... sort of retired...
KenBuja
Numbers like 3.06370662743992E-03 are not below zero. They are in scientific notation, which is equivalent to 0.00306370662743992.
If you'd like to make sure you don't get numbers like that, you can use the Text function to return numbers at a set number of decimal places.
DavidPike
MVP Notable Contributor
var dist = DistanceGeodetic($feature, w_point, 'meters')
