Arcade / FeatureSetByName error 'Object Not Found $map2'
2049
11-15-2024 06:23 AM
Labels (2)
FrankBrenner
Ver ARCGIS 3.3.1
Cannot get past error 'Object Not found $map2'
Checked the Properties of 'Map2' to identify any alias .. none
_/
var x = FeatureSetByID($map, 'FireServiceArea', [*], true);
var z = $feature.name;
return z
<ERR> Invalid Expression / Error on line1 / Identifier expected
var x = FeatureSetByName($map, 'FireServiceArea', [*], true);
return z
<ERR> Invalid Expression / Error on line1 / Object not found $map
KenBuja
The Arcade Labeling profile doesn't have access to the $map profile variable, only the $feature variable.
KenBuja
