Corner Labels using Graticules, Print Layout, ArcGIS Pro
1068
11-15-2024 06:47 AM
GrizzlyBear
Hi everyone,
I'm working on a map in ArcGIS Pro and trying to create print layouts. I trying to create Corner Labels using Graticules to show parallels of latitude and meridians of longitude for a map of the UK. However, instead of displaying the actual latitude and longitude numbers, the corner labels are showing zeros (0).
Here’s what I’ve done so far:
  1. Added a Graticule using the "Add Grid" option in the Layout View.
  2. Configured the Graticule properties to display corner labels for the grid.
  3. Selected the Coordinate System as WGS84 (Geographic).
  4. Customized the Label Format to Decimal Degrees.
I expected to see values like 51.5074°N, 0.1278°W, but all I get is 0.0° ( at the corners).
I saved a working (desired) Graticule/corner label as a style from a portrait layout (A3 Portrait), but when load it on a landscape (A3) one I still get the 0.0° ( at the corners).
Does anyone know how to fix this so the actual latitude/longitude numbers are displayed? Could it be an issue with the projection, extent, or some specific setting I’ve missed?
