Arcade Expression to Calculate Field based on a Sort Date field
5202
12
05-24-2023 11:51 AM
BrianHumphries1
hello,
I am trying to use the SequentialNumber() for Calculate Field but I would like to calculate the Field based on the a field called  SampleDate in ascending order.
I have tried using the helpers and modify the code block but failed.
i tried a arcade expression(below) but got null values as retuned values
// Arcade  for SequentialNumber
var rec = 0;
function SequentialNumber() {
    var pStart = 1;
    var pInterval = 1;
    var SampleDate = $feature.SampleDate;  // Name of the field used for sorting
    // Access the global feature set
    var Opp_table = FeatureSetByName($datastore, 'SDEP.SDEADMIN.WaterSampleInspectionsOperator');
    // Sort the features based on "SampleDate" field
    var sortedFeatures = Sort(Opp_table, SampleDate, 'ASC');
    if (rec == 0) {
        rec = pStart;
    } else {
        rec = rec + pInterval;
    // Assign the sequential number based on the sorted order
    return rec;
Any help would be much appreciated
JohannesLindner
This should work as long as you don't have exactly the same dates in multiple rows:
var sd = $feature.SampleDate
return Count(Filter($featureset, "SampleDate < @SD")) + 1
Have a great day!
Johannes
BrianHumphries1
I do have dates that are identical.😬
JohannesLindner
var sd = $feature.DateField1
var oid = $feature.OBJECTID
var previous = Filter($featureset, "DateField1 < @SD")
var same_lower = Filter($featureset, "DateField1 = @SD AND OBJECTID < @oid")
return Count(previous) + Count(same_lower) + 1
Have a great day!
Johannes
BrianHumphries1
Maybe I am not setting this up correctly, I'm still getting null values... The field I am trying to calculate is a LONG field will this cause an issue with the expression?
This is what I used is this correct in what you suggested?
var rec = 0;
    var pStart = 1;
    var pInterval = 1;
    var previous = Filter($featureset, "$feature.SampleDate < ")
    var same_lower = Filter($featureset, "$feature.SampleDate =  AND OBJECTID < @oid")
    if (rec == 0) {
        rec = pStart;
    } else {
JohannesLindner
No, just use my expression as it is.
Have a great day!
Johannes
BrianHumphries1
Good Morning,
Running this Code produced this error... See Below
var previous = Filter($featureset, "SampleDate < @SD")
var same_lower = Filter($featureset, "SampleDate = @SD AND OBJECTID < @oid")
Calculate Field
Parameters
Input Table Operator Inspection
Field Name (Existing or New) UID
Expression
Expression Type ARCADE
Code Block
Updated Input Table Operator Inspection
Field Type TEXT
Enforce Domains NO_ENFORCE_DOMAINS
Messages
Start Time: Thursday, May 25, 2023 8:58:46 AM
ERROR 002717: Invalid Arcade expression, Arcade error: Failed to query statistics, Script line: 6
Failed to execute (CalculateField).
Failed at Thursday, May 25, 2023 8:58:46 AM (Elapsed Time: 0.50 seconds)
BrianHumphries1
Good Moring Johannes,
Here is a some data that is in my table for an example
SiteNameUIDSampleDateCl
Lab Site 1 2021-01-01 5:00:001.8
Lab Site 2 2021-01-01 5:00:001.6
Lab Site 3 2021-01-01 5:00:001.8
Lab Site 4 2021-01-01 5:00:002.6
Lab Site 5 2021-01-01 5:00:001.6
Lab Site 6 2021-01-01 5:00:001.6
Lab Site 7 2021-01-01 5:00:002.6
Lab Site 8 2021-01-01 5:00:002.3
Lab Site 9 2021-01-01 5:00:004.1
Lab Site 10 2021-01-01 5:00:001.6
Lab Site 11 2021-01-01 5:00:002.6
Lab Site 12 2021-01-01 5:00:002.5
JohannesLindner
I have no idea why this is happening...
Try doing it with a Python script instead (not in the Field Calculator, in the Python Window):
table = "TestPolygons"  # the table path or layer name
sort_field = "DateField1"  # the sort field
number_field = "IntegerField1"  # the field that will be calculated
i = 1
with arcpy.da.UpdateCursor(table, [number_field], sql_clause=[None, "ORDER BY {}".format(sort_field)]) as cursor:
    for row in cursor:
        row[0] = i
        cursor.updateRow(row)
        i += 1
Have a great day!
Johannes
BrianHumphries1
Hello Johannes,
I ran as python and received a RuntimeError..,
table = "Water Sample Inspections Operator" # the table path or layer name
sort_field = "SampleDate" # the sort field
number_field = "UID" # the field that will be calculated
i = 1
for row in cursor:
row[0] = i
i += 1
File "<string>", line 9, in <module>
RuntimeError: Invalid parameter value passed to function [SDEP.SDEADMIN.WaterSampleInspectionsOperator]
