Arcade Date expression for symbology in ArcGIS Pro 2.2.0
1591
06-29-2018 08:06 AM
BruceAnderson1
I'm trying to use an Arcade expression to symbolize data based on a date field. I want to display records for each Year/Month combination. the expression verifies and seems to work but if I look at the counts for the year/month groupings they are off by one month. e.g. the number of records for 2018/5 are showing as 2018/4. Any idea what might be causing this?
here is the expression that I'm using:
Year($feature.observation_date) + "/" + Month($feature.observation_date)
KenBuja
MVP Esteemed Contributor
From the documentation: Date Functions | ArcGIS for Developers
Returns the month of the given date. Values range from 0-11 where January is 0 and December is 11.
KenBuja
BruceAnderson1
Thank you.
