ARC Pro Freezes When Trying to Delete Feature
1116
11-06-2025 09:11 AM
Labels (3)
Quincy
Hello, I've been having an issue where whenever I try to delete a feature arc will freeze without fail, and I have to restart my computer. I am using Pro 3.5.4 . I have tried creating a new map within in the project and had the same issue. I have also tried editing a different dataset in a different project and still have the same problem. Any ideas on what could be causing this?
DanPatterson
If it happens in a new project with a different dataset and you are working with locally stored data then you can try one of two things before contacting tech support
How To: Perform an ArcGIS pro Soft Reset
How To: Perform a Clean Uninstall and Reinstall of ArcGIS Pro
... sort of retired...
Quincy
Hey thanks for your response, I did a complete re-install and am still having the same issue 😕
DanPatterson
If it isn't the data (source and location), the location of Pro (local install vs other options), then
Tech Support is your remaining option.  Good luck
