Kate,
Please check the ArcGIS Pro 2.0 system requirements—ArcGIS Pro | ArcGIS Desktop
Also check Can You Run It?
~Shan
The minimum surface pro meets the requirements. I run Pro and Map on a surface Book with no issues and have never experience these issues. It could be anything from conflicts with other software to something you are doing in your workflow. You have identified editing as a culprit, so perhaps it is the data or its type and where it is being stored that is a problem. You will need to keep record of the exact message, if any, and exactly what you were doing. when a crash happens.
I uninstalled and reinstalled ArcPro 2.0 and downloaded the latest patch
Using the create feature tool I added a polygon to my feature class
IN the editing menu I clicked save to save the edits and the program crashed giving me this error message
error message image or text is missing
As a very interesting test switch to OPENGL since the one you use is DIRECTX by default, you can do this in ArcGIS PRO> Project> Options> Display
Hi Francesca - thanks for your reply- I tired this but no luck -still crashing every time I edit
That is a conflict crash for sure... tech support material
test with a clean uninstall
but first check the capabilities of your PC
