Arc GIS Pro Raster Extraction
634
10-03-2025 06:46 AM
Anish
I am encountering an issue with ArcGIS Pro when performing raster operations, specifically the Creating Slope Map from DEM and Export Raster tools. After extraction, the output raster's cell size and rows/columns seem to change, even though I have not altered the input data. Here is a summary of the problem:
Problem Details:
  • Before Extraction:
    • Raster Dimensions: 4348 Columns x 2335 Rows
    • Cell Size: 31.09 x 32.72
    • Raster Format: TIFF
    • Pixel Type: Floating Point
  • After Extraction:
    • Raster Dimensions: 4349 Columns x 2336 Rows (slight increase in size)
    • Cell Size: 32.05 x 32.72
    • Compression: None
I have tried setting the Snap Raster and Extent to match the original raster, but the issue persists. I would appreciate any advice or steps to ensure that the output raster matches the input raster exactly in terms of cell size, rows/columns, and alignment.
RichardDaniels
MVP Regular Contributor
There is option to SET the output cell sizes vs. letting it default. Notice 1 row and column was added, most likely the projection being used has rotation causing these to be added.
