Append feature not working
1526
09-13-2021 04:19 AM
FionaMcLaughlin
Hi all,
Recently have come across when I go to Append a shapefile into a feature layer the number of Output Fields reduces to half when I click run. Even after deleting and replacing necessary fields.
Have deleted and re-downloaded the software and this doesn't seem to help.
Any theories or advice would be great, Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi @FionaMcLaughlin ,
Have you tried the same workflow using a File Geodatabase feature class rather than a shapefile?  I try to avoid shapefiles like the plague.
DavidPike
MVP Notable Contributor
The data types might be a bit off e.g. dates aren't datetimes in shapefiles.  Possibly try exporting the shapefile into a table/feature class within a file geodatabase then see if that solves it (more of a guess than anything).
