Animation in ArcGIS Pro
8442
6
02-17-2015 11:32 AM
MichaelWalton
Remember how we can make a movie clip in ArcScene? I was wondering if that feature is coded into ArcGIS Pro...also it would be cool if you could have layers hidden and turn on at certain points during the fly-through video.
Tags (1)
JeremyWright
Michael,
This feature is not in the current release of ArcGIS Pro.  We plan to add animation and video export at a later release.
Regards,
Jeremy W.
JeremyWright
Michael,
Regards,
Jeremy W.
AdamForknall
Any indication of when the animation/video export features will be added?
DrewFlater
AdamForknall
When is the next release due to come out?
michelekoons
It's out now.
Galen_S_MnDOT
Has anyone seen any decent demonstrations of time lapse animation using ArcGIS pro's features?
I've gotten as far as creating a heat map time lapse animation with key frames established from the steps/intervals for the time data, but the transition from each increment's data to the next is still more abrupt than I'd like.
I'm hoping to figure out which setting allows me to set a fade/dissolve between each increment in the time series, but each time I've tried experimenting with the key frame transition settings, it seems to override the time component and each key frame becomes stuck on the same time stamp.
Oh, and I'm using ArcPro 2.4 at the moment.  My agency intends to roll out 2.7 either this week or next; I'm hopeful that adds some additional animation functionality.
