AHP Extension
4736
05-16-2024 10:51 AM
PegahAmjadian
Hello,
I need to install an AHP plugin on my ArcGIS Pro, but it seems it doesn't exist. Can anyone help me?
George_Thompson
Esri Notable Contributor
Can you provide more information about the plug-in?
Where does it come from?
  Is this it: https://mhdhabboub.com/2018/03/10/ahp-for-arcgis/
--- George T.
Robert_LeClair
Esri Esteemed Contributor
If I'm tracking the same AHP Add-in for ArcGIS Pro, you can download it at this GitHub link here BUT it only works for ArcGIS Pro 2.x versions instead of the ArcGIS Pro 3.x environments.  There is a note within the GitHub page that discusses AHP migration to ArcGIS Pro 3.x and forward compatibility.  My guess is you would have to migrate the code to the .NET 6 Desktop Runtime x64 framework for ArcGIS Pro 3.2 and earlier releases as ArcGIS Pro 3.3 uses .NET 8
YongBinWongYongBin
Hi Robert,
I am installing the AHP Add-In. I recently upgraded my ArcGIS Pro to 3.x., and the add-in, unfortunately, needs to be migrated for ArcGIS Pro 3.x environments. I found a manual for the process but I am overwhelmed by it. I am currently stuck on the Visual Studio part as I can't find the ArcGIS Pro SDK for .NET templates after installing the extension ArcGIS Pro SDK package (Step 8). I would very much appreciate it if you could recognise any tutorials with a step-by-step guide that I can refer to.
Thank you in advance. Sincerely appreciated.
Bin
Robert_LeClair
Hi Bin - I'm not aware of any Esri tutorials on how to install and/or use the ArcGIS Pro SDK package.  Perhaps a call to Esri Support Services to request assistance on installing the SDK would be the best approach?
tcantbenormal
I recently developed an ArcGIS Pro add-in for AHP, FAHP, and Sensitivity Analysis. It is compatible with ArcGIS Pro 3.5 and above. Anyone can check it out on my GitHub repository here:
https://github.com/tcantbenormal/Ahp-Fahp-Analyzer-Add-in-For-ArcGIS-Pro.git
Any feedback would be greatly appreciated!"
